Tractor I D
Alvin-va
06-04-2001 18:28:49
Trying to ID a MM I found in the weeds today.Not familiar with this brand, mostly green and red toys around here.Has MM decals on hood,but I can't read model #. Castings on rear read BF Avery. Tractor looks like a picture I found on this site of a MM BF, except this one has a wide front end.Have found info on YT to help me locate serial number when I go back .If this is a BF wide,is this rare?Owner says rear wheel bearings bad,reason for parking several years ago,are parts hard to find for this tractor?Any help greatly appreciated.
Pete
06-04-2001 21:03:32
 Re: Tractor I D in reply to Alvin-va, 06-04-2001 18:28:49
IF it is a model BF the serial number should be on the top of the right frame rail in front of the brake pedals. It would also have a 4 speed trans with reverse in the center forward position and a round gearshift lever.If it has a flat handle gearshift lever and sized like a Farmall cub it could be a model V. If you sit to the side and it is in the size of a Farmall A it would be a model BG1 Row. They are nice little tractors.
