Ammeter wiring for MM RTU 1947
Dave Allen
06-15-2001 10:47:29
Restore almost complete. Rewired per schematics on purchased wire loom also checked against schematics in back issues of Prairie Gold Rush.
All works as expected except ammeter reads backwards i.e. +/- sensing is reversed. Tractor has original 6 volt battery/positive ground w lights, generator, starter, distributor ignition.
I tried reversing +/- leads on ammeter -- no help.
Any ideas????? ????? ??
kelvin
06-16-2001 19:31:06
 Re: Ammeter wiring for MM RTU 1947 in reply to Dave Allen, 06-15-2001 10:47:29
Is your ammeter the original or a replacement?
Is there any chance you can swap another ammeter in place of it? Is there any chance you took the wires off and put them right back on the same way?
Dave Allen
06-19-2001 18:02:42
 Re: Re: Ammeter wiring for MM RTU 1947 in reply to kelvin, 06-16-2001 19:31:06
I purchased a new ammeter (mail order) -- the original was completely rusted out. I don't have another working ammeter to try. I double checked to make sure I had reversed the + and - leads and I apparently did it right. I will be contacting the ammeter supplier to see if he has any ideas on why the sensing is reversed. Thanks for the response. Dave Allen
