445 pto
james
06-15-2001 12:32:56
my pto stays ingaged. i would like to know if this is normal or what i would need to do to fix it
J. Kinsey
06-15-2001 13:06:58
 Re: 445 pto in reply to james, 06-15-2001 12:32:56
James,
If by staying engaged you mean that it simply doesn't stop when you disengage the PTO with the lever, it could be normal. These tractors do not have any sort of PTO brake so they tend to continue running even when disengaged. If however it will still drive a piece of equipment that doesn't drive real eazy, the clutches are most likely warped and will have to be replaced to correct the problem. Can't help with how much the discs cost.
JK
james
06-16-2001 01:38:10
 Re: Re: 445 pto in reply to J. Kinsey, 06-15-2001 13:06:58
thank you jk
