Governer Problems on MM U`
Mark
06-25-2001 18:18:59
I have a MM U that i am haveing governer problems with it. When the tractor is not running the governer work just fine I open the throttle up and the butterfly opens no problem. pull the throttle back the butterfly closes no problem. I start the tractor up open the throttle a little and the butterfly open all the way pull the throttle back and the engine still keeps running at a high rpm. the problem is the governer is not bring the motor back to and ideal after the governer opens up. So what do I need to do to fix this problem any info would help thanks
Nug
06-26-2001 17:21:41
 Re: Governer Problems on MM U` in reply to Mark, 06-25-2001 18:18:59
Check your governer rod, if it is too long it will act like that. With rod unhooked from carb. ,
open throttle on tractor and hold carb. wide open with your hand, rod should be very close and drop right into the hole. Tractor must not be running to do this. Hope this helps.
Nug
