MM 670 Deisel power steering / hydraulic repair
Steve Sax
06-26-2001 08:39:54
I am looking at buying a Minneapolis Moline model 670 Deisel tractor. The power steering does not work and I have been told that the power steering is run by the hydraulics, and if so, then the hydraulics ( and the loader which hasen't been mounted for years)dont work either. Can anyone confirm this and do you have any idea what it takes to repair / replace the hydraulic pump on this tractor.
Thanks
Harrold Rhodes
07-08-2001 16:32:58
 Re: MM 670 Deisel power steering / hydraulic repair in reply to Steve Sax, 06-26-2001 08:39:54
If the 670 is a super the steering is hydrostatic. It is powered by a belt driven pump at right front of engine. Hyd pump is mounted on left front of engine. If not super and it has 3-pt it is powered by a piggyback pump mounted behind the regular hydraulic pump which will be on the back of trans case. Either way the main hydraulics are seperate from the power steering.
