Governer trouble
Dave S
07-06-2001 15:44:37
I just put a new late model U manifold on my
51 UTS. The tractor hasn't been run for about
a year. Upon starting it was like the govener
wasn't even hooked up, the engine was screaming
I shut it down right away. There is no binding
in the linkage. The arm that goes from the govener
to the carb just flops around with ease.
Any one have any ideas? Thanks
yesenia
04-21-2002 11:35:13
 Re: governer trouble in reply to Dave S, 07-06-2001 15:44:37
were can i e-mail jeb busch about the fcat program he's working on.
JIM
07-06-2001 18:39:33
WHEN I DID THAT TO MY U I HAD TO ADJUST THE LINKAGE . GOOD LUCK JIM
Dave S
07-06-2001 19:36:01
 Re: Re: governer trouble in reply to JIM, 07-06-2001 18:39:33
The linkage to carb is all the way down. With tracor throttle in slow position at the govener
willstill open carb. I can push it down with my
finger, but it will still work it's way up.
Shawn
07-06-2001 19:49:53
 Re: Re: Re: governer trouble in reply to Dave S, 07-06-2001 19:36:01
Hello,
your new manifold hangs your carb lower then the old one.
with the tractor off,
push the trottle all the way open,
the governor rod should be all the way up.
hold the trottle open on the carb, and make your rod the leght bettween the two. that is the starting place, then you may have to adjust for rpms and other fien tunning
if it still dont work email me at shawn7240@yahoo.com
and i will help you out some more
Shawn
Dave S
07-07-2001 15:48:07
 Re: Re: Re: Re: governer trouble in reply to Shawn, 07-06-2001 19:49:53
I cut the rod between carb & governer after checking lenght like I was told . Seemed to help alot. Where do I start to adjust the carb from here? Thanks
Harrold Rhodes
07-07-2001 05:40:55
If U happens to be propane the control lever can slip on the throttle shaft and require adjusting.
