MM 5 Star need to add hydro fluid
John
07-25-2001 08:04:28
I have a MM 5 star and the hydro line got pulled
off over the weekend. I was quickly able to reattach it but now I need to know where to check the hydro level and how to fill it. Sorry, I have no manuals. Is it under the seat? Do I have
to pull bolts. Any help and suggestions are appreciated.
Thanks,
John
J. Kinsey
07-25-2001 16:20:38
 Re: MM 5 Star need to add hydro fluid in reply to John, 07-25-2001 08:04:28
John,
There is a plate under the seat that had 2 levers protruding from the top (assuming it has 3 point) that is held on by 4 1/4" capscrews. clean the accumulated dirt from around it before you remove the bolts then remove it. Add oil until the level is about 3/4" to 1" below the surface where the plate sits. Before re-installing the plate, turn the levers (or stubs if they are broken off) until the pins are as far forward (toward the front of the tractor) as they can get and that the three point lift lever is in the neutral position. You may have to replace the gasket under the plate if it is shot.
JK
Brian
07-28-2001 11:25:39
 Re: Re: MM 5 Star need to add hydro fluid in reply to J. Kinsey, 07-25-2001 16:20:38
Replace oil with Dextron type trans fluid.
