Hydraulics
eric
07-31-2001 15:50:02
I HAVE A 1963 MOLENE AND MY HYDRAULICS DO NOT HOLD MY BUSH HOG UP..THE FLUID RESERVIOR IS FULL OF FLUID AND THE PUMP SEEMS TO BE WORKING FINE..IT WILL CREEP DOWN EVEN WITH THE TRACTOR IS RUNNING AT HIGH RPMS...I HAVE CHANGED THE FILTER SO THAT IT SHOULD NOT BE A PROBLEM..IS THERE ANY ADJUSTMENTS ON THE PUMP THAT I CAN MAKE TO HELP WITH THIS PROBLEM..THANKS FOR ANY HELP..ERIC
Kelvin
07-31-2001 20:48:03
 Re: hydraulics in reply to eric, 07-31-2001 15:50:02
Well Eric,
You didn't say what model tractor you had, but I'm guessing that yours is probably a Jetstar or a 4-star.
I had a similar problem with my 335 and replacing the piston seal helped it a whole lot. (still leaks down, just not real fast.)
eric
08-01-2001 18:49:48
 Re: Re: hydraulics in reply to Kelvin, 07-31-2001 20:48:03
thanks for the information kelvin,,you were right i have a jet star 2....eric
