5-Star/M-5, pullers?
KB
08-02-2001 18:38:01
Can either of these tractors be turned into pullers? I know the rule of thumb, $ = h.p. Just have not seen too many of these pull in this area, most all tractors in the 7500 lb - 9500 lb classes are 4020 JD's and some 560's. What about turbo on a diesel?
plowboym5
02-02-2004 13:37:31
 Re: 5-Star/M-5, pullers? in reply to KB, 08-02-2001 18:38:01
ohhh yeah. definetly u can make a great puller out of an m5 diesel.ive got an m5 diesel with stock cubes runnin a 4in. turbo diesel and runnin with 4320 jd"s. ive got it in the 5000# class up to 11000#. NO KIDDIN.VERY COMPETETIVE!!! cheap too.
CHARLIE
08-28-2001 09:51:34
I have an M-5 puller that is dyno tested at 250hp. and it it naturall aspirated. It is run on propane and runs with just about anything in the light classes. I pull 4th gear in the 5500# and 7500# clases. I used a diesel block because it is much stronger with a 6" crank and major heasd work. I have been pulling it for four years and she is still running strong.
Jp
08-03-2001 07:36:44
5-star would be a great puller, but you have to find the jugs that interchange. Great puller because you can get over 100 hp, and fit into 5000 lbs.
