MM445 POWER STEERING
JIM
08-11-2001 19:58:23
i was turning with a bucket of dirt
and a flat tire something popped , and the steering got real hard. up on jack stands and the engine off it turns, with engine runnung, the eheels don'turn any ideas what snapped?
Benny
08-15-2001 14:07:42
 Re: MM445 POWER STEERING in reply to JIM, 08-11-2001 19:58:23
There is a woodruff key that holds the arm that attaches to the drag links to the shaft. And there is another key that holds the gear that moves with turning of the wheel. It sounds like you are going to need to drop the rack out and check these. Without the engine running it could have enough fritction to turn. Check a service manual for pocedures.
