Checking Trans Fluid on M5
Daniel Gough
08-15-2001 18:36:46
Hello, I recently purchased a 1963 M5 and can't find where to check the transmission fluid level. If someone could point me in the right direction it would be greatly appreciated. Also what type and weight oil would you recommend for the transmission, Hydraulics and engine (LP).
Harrold Rhodes
08-25-2001 17:50:39
 Re: Checking Trans Fluid on M5 in reply to Daniel Gough, 08-15-2001 18:36:46
There are two small pipe plugs on the right side of the trans case. The top one is for the amplic-torc compartment if equiped with torc. With engine running and torc in high range the torc compartment will fill to the level of the higher plug. It also needs to run out at the lower plugs level. EP 80 or 90 is reccommended for trans. Type A is reccommended for hydraulics. 20W low ash non detergent oil is reccommended for engine if on LP. 20 or 30W detergent oil is reccommended for gas or diesel.
