206 motor in a R
Augie
09-09-2001 20:08:11
Have any of you guys ever swapped a ZA motor into a R? I've got a ZA with a busted rear end and a R with a bad stuck motor.
Will the ZA clutch and flywheel fit in the R bellhousing or will I need to use those parts from the R? Anything else to pay special attention to?
Kelvin
09-12-2001 08:35:02
 Re: 206 motor in a R in reply to Augie, 09-09-2001 20:08:11
I haven't done this, but having restored both R's and Z's, you will have to use the R flywheel and clutch. (you could probably make the ZA clutch work somehow, but it would require some special machine work.) It seems like everything else should bolt up. Remember, the R transmission is now somewhat overloaded and may not stand up to all the abuse the ZA engine could dish out.
Joe Leising
09-12-2001 19:46:38
 Re: Re: 206 motor in a R in reply to Kelvin, 09-12-2001 08:35:02
It does require the R clutch and flywheel. If it is just for the occasional pull ands or show/parade if the R rear is in good shape it should hold up ok. Mine has!
Joe
P.S. Here is a link to pictures of my toys!
