445 Industrial
Dan Steinmetz
09-10-2001 18:56:42
Recently purchased this unit with a MM loader. Would like to know any info on this style tractor. (age, horsepower, amount manufactored, etc.)
M/n- B1D
S/n- 11100143 (tag on the chassis)
M/n-206 H-4
S/n- 1000 121 (tag on the motor)
M/n- 543
S/n- 629 (tag on the loader)
Thanks!
BMG
09-11-2001 13:59:50
 Re: 445 Industrial in reply to Dan Steinmetz, 09-10-2001 18:56:42
Dan,
You've got a 1957 445 Industrial. The gas and LP versions were made from 1956 to 1958 with 645 units produced in that time. There were 25 diesel 445 Industrials produced in 1958 only with serial numbers starting with 153XXXXX. The gas version produced just under 40 horsepower.
I've got a 1957 445 Industrial also with an Ottawa loader and backhoe but it's in really rought shape (ser # 11100089). The crankcase is almost split in two from its rough life.
Brian
Dan
09-13-2001 19:13:00
 Re: Re: 445 Industrial in reply to BMG, 09-11-2001 13:59:50
Thanks for the info. How long have you had yours? Any issues you've had with parts/ repairs?
BMG
09-16-2001 17:49:18
 Re: Re: Re: 445 Industrial in reply to Dan , 09-13-2001 19:13:00
Dan,
I just got mine this summer. It's going to sit a while before I get around to restoring it. It's not useable in its current state. I've heard that the rear hubs were prone to breaking. They're a one-piece hub with 8 bolts mounting the rim center. Someone has replaced mine with standard 2 piece 9 bolt hubs and homemade 3/4" steel plate wheel centers. I hope your tractor is in better shape than mine!
Brian
Dan
09-16-2001 19:17:38
 Re: Re: Re: Re: 445 Industrial in reply to BMG, 09-16-2001 17:49:18
Everything looks pretty good so far. Some leaks on the power steering, but runs really well. Just missed an auction in the area yesterday with a 445 and loader on the billing. Would have liked to see what it went for, or shape it was in.
