Water pump distributer drive gears
aaron
10-02-2001 10:45:40
i removed the water pump from my m 670 and mistakenly removed the dist assembly also.my question: are there timing marks on the drive and distributer gear? there appears to be one on the large gear,but i can't find one on the small dist. drive gear. are these gears supposed to be marked and meshed or do i just put it all back together,pull out the dist,set the flywheel to tdc and time it that way? any help appreciated.
Kelvin
10-03-2001 11:55:33
 Re: water pump distributer drive gears in reply to aaron, 10-02-2001 10:45:40
On the U's that is what you do. set #1 cylinder to TDC and put the distribuitor in with the rotor pointing to whichever lug in the cap is #1.
