335 update-- Color's and power steering parts -Thanks Ken!!!
larry
10-20-2001 17:03:06
My tractor is a 57 serial number 10401047. I have an orginal 1957 MM ad that shows the wheels and grill almost red, is that correct??. Should the belly be red also as it is showing a lot of red in scaped up places?? I am 100% sure it is a orginal paint tractor! Also will the power steering parts off a 445 work on a 335 as I need some parts
John
10-21-2001 06:08:23
 Re: 335 update-- Color's and power steering parts -Thanks Ken!!! in reply to larry, 10-20-2001 17:03:06
Most of the power treering parts will interchange between the 335 and 445. The stuff in the front end is the same. Some of the shafts and lines are different from the unit back to the steering wheel or rear hyd system.
John
BMG
10-20-2001 18:40:24
Larry,
The belly of your 335 should be the same color prairie gold as the rest of your tractor. The red you see showing through under the paint was the primer Moline used on their cast parts. The wheel centers should be red and I do believe red grill screens are correct. Sorry can't help you with your power steering question.
Brian
