MM U PTO shaft
fat boy
10-31-2001 17:13:05
I have a MM U that the PTO is shaft is stripped. I have an old junk Z closeby. Are these the same shafts? Can I use the one from the Z oin the U? Thanks.
Pete
11-01-2001 22:36:10
 Re: MM U PTO shaft in reply to fat boy, 10-31-2001 17:13:05
The U & Z have two different length shafts internally.The U has a little shorter shaft than the Z.The rear pto housing with engagement that bolts to the rear end is both the same.
