Compression distance on pistons
Willie
11-05-2001 11:04:14
Compression distance on z 3-3/4 pistons, or u-302 pistons?
Jeremy Fiorelli
11-07-2001 21:01:13
 Re: Compression distance on pistons in reply to Willie, 11-05-2001 11:04:14
Once apon a time I told someone they may be able to put the 3 3/4 (220) U 302 pistions in the ZA's 206 and to do some checking into it they found out the compression height was different and it wouldn't work.
Jeremy Fiorelli
Willie
11-09-2001 10:39:03
 Re: Re: Compression distance on pistons in reply to Jeremy Fiorelli, 11-07-2001 21:01:13
I just need to know what the U 302 and ZA piston compression ratio's are to see if they will work with what I want to do. My sealed power book doesn't have this listed on these pistons and neither does my Moline book.
Jeremy Fiorelli
11-11-2001 17:29:50
 Re: Re: Re: Compression distance on pistons in reply to Willie, 11-09-2001 10:39:03
Willie
I don't have anything that would give you any compression ratios for different pistions. I do have a page that has compression ratios for the differen't heads. I'll leave a link for it. The 220 is in the top list towards the bottom. The 206 used in the ZA and ZB is in the bottom list.
