MM-U production year?
Pat Mitchell
11-07-2001 09:36:51
Husband has brought home an old MM u family tractor with intent to restore (against wifes wishes for new "stuff" for house instead).
Anyway, he needs to id year and not sure which number on the tractor to use to look up production year via serial #. Has numbers on body and engine.....none match list of serial # on the site. Thanks. He has found it was called an MM-U cane tractor if this helps any.
kelvin
11-07-2001 10:56:17
 Re: MM-U production year? in reply to Pat Mitchell, 11-07-2001 09:36:51
The tractor serial no. is on the plate on the right side of the transimssion near where the belt pulley would mount on a regular farm tractor.
Congratulations! a U cane is a pretty rare tractor. If you are looking for serial number data, I would check the serial no. lists on the MM website. jetstar.minneapolis-moline.com
Pat Mitchell
11-08-2001 17:15:41
 Re: Re: MM-U production year? in reply to kelvin, 11-07-2001 10:56:17
Thanks for your help Kevin.
