Charged-up MMZ
DLP
11-09-2001 18:30:44
In restoring my Z, I wanted to convert over to a 12 volt Delco altnator from a 6 volt generator. Because of mounting restrictions due to the air cleaner, I had to abandon this idea. I then called a gentleman who has worked on generators for many years. He said if I had a healthy 6 volt generator to mount a 12 volt regulator on it & go.He said if I put a heavy load on it that it might heat up some, but on a tractor it should keep the battery up. Has any one else done this? Is there an altnator that will mount under the air cleaner?
Jeremy Fiorelli
11-12-2001 17:38:44
 Re: Charged-up MMZ in reply to DLP, 11-09-2001 18:30:44
You can put an altinator on the Z's it is a little work but it can be done. It's been 6 or 7 years scence I did this so hopefully I'll remember everything. I had to make a different bracket for the Air cleaner to move it up just a little (so I could get the bottom off it) I didn't have to modify the hood. I used the pulley off the orignal generator on the altinator and made a new bracket to hold the alt. The side curtin dosen't come completly closed now but it use to if I had a shorter belt it would again. It is a tight fit and took a little work to get the alt set right so I had some ajustment for the belt and so I could get the bottom off the aircleaner. I also had to turn the rear housing of the alt to give it enough clearance. It had an indent in the back that gave enough clearance for the block. I can probably get you some pictures if you would like.
Roger A. (NY)
11-10-2001 05:01:50
I have three tractors that I have just changed the regulator and battery (no lites that work on these tractors) and they charge fine. I also put a 12 volt battery in my 1946 Cletrac AG6 and it went right to charging without changing the regulator. Also know a fellow that put a 12 volt battery in his Farmall M and it has charged for years. I would try it if the generator works now on 6 volt.
Roger R
11-18-2001 16:57:09
 Re: Re: Charged-up MMZ in reply to Roger A. (NY), 11-10-2001 05:01:50
I have a 40 RTU that started with no wiring at all except for the kill. (mag) It still has the mag but I added a starter lights and a small GM altrtnator. I usad the Moline pulley and it all fits under the hood.
