Just got a MM UTIL-M
Erik Larsen
11-21-2001 14:32:11
Hello
This weekend I just got a U TIL-M traktor, it is in pore shape and need a donor U to be good. I do not know this type of model, is have an extention between the gear box and engine. I do not know this type, what do you this should I keep it or just use the parts. Evt. scrap ??
Best regards, Erik Larsen
BMG
11-21-2001 19:02:03
 Re: Just got a MM UTIL-M in reply to Erik Larsen, 11-21-2001 14:32:11
Erik,
I'm guessing you're across the big pond in Europe somewhere. Here in the states a UTIL-M is a rare tractor. There were only 357 made in 1953. Most if not all of them were produced for the military hence the "M" in the model designation. The extra casting between the engine and transmission is a shuttle shift. There should be a lever connected to it that is used for quick changes from forward to reverse. The "L" in the model designation stands for this added shuttle shift transmission. If I found that model here in the states I'd definitely fix it up using parts from a more common U model.
UTIL-M 12 volt ignition serial # 07900001-07900002
UTIL-M 6 volt ignition serial # 05400001-05400355
Brian
