Battery Polarity--49UTS
BKG
11-23-2001 19:59:01
Thanks Keith and Kelvin.....trailered my tractor home successfully. Another question ..could you tell me the battery polarity...is it a negative ground? This is still the original 6 volt system with the generator..thanks for all your help.
Bill Becker
11-28-2001 20:02:28
 Re: Battery Polarity--49UTS in reply to BKG, 11-23-2001 19:59:01
All Moline 6 volt systems were positive ground. All 12 volt systems were negative ground
Kelvin
12-01-2001 15:27:43
 Re: Re: Battery Polarity--49UTS in reply to Bill Becker, 11-28-2001 20:02:28
My Granddad's '54 Zb is 12v and it has always been positive ground. I'm thinking that the switch to negative ground occured ag the time MM switched to alternators.
Keith
11-26-2001 01:53:36
Good news that you got it home. I guess Brian answered your polarity question. Both my U's have been converted to 12V but I do have all manuals for the original setups. If you get stuck on anything, email. Kelvin has certainly helped me before! I have his email committed to memory. Good luck.
Keith
BMG
11-24-2001 09:21:36
BKG,
It should be positive ground if its still has the original 6 volt system.
Brian
