G1000 lift won't go down
mcj
12-09-2001 21:43:34
The three point lift on my G1000 won't go down when it is moved into the up position. The tractor has the 'tel-e-flo' system. I have had a subsoiler on it, but it still won't retract. I have an I&T manual for it, but before I start troubleshooting using the manual, has anyone had this problem and found a quick adjustment that will cure it?
JK
12-10-2001 05:41:23
 Re: G1000 lift won't go down in reply to mcj, 12-09-2001 21:43:34
Check that the rate lever under the seat is not turned to the left side and that the position control lever isn't up (round lever with round knob)
John
