425 engines
bill
12-17-2001 20:36:15
I have MM GDB with a 425 diesel engine. Is there any differece between the gbd 425 and the newer model MM's with 425's in them?
Zachary Holman
08-13-2002 08:13:00
 Re: 425 engines in reply to bill, 12-17-2001 20:36:15
Looking for a 425 Engine for a cadillac or a 500
JK
12-17-2001 21:08:43
Bill,
I think only newer tractors with a 425 Diesel is the GVI and G704. The later tractors that had the 425 gas/LP engines had a 451 diesel (ie G900, G950 & G955). The 425's above were very similar to the one in your GBD. I think the heads & some of the manifolding was a little different, but the injection pump and injectors were basically the same. The bellhousing was the same also. The later 451's have a small bell like the 504's in the G1000's etc (about like where your bellhousing adapter bolts to the transmission). They also used the Rosa Master injection pumps instead of the American Bosch units that were on the earlier ones. If I remember correctly, some (if not all) of the crank journals are smaller on the GBD than the later ones. There were some real late 955's that had the full circle rear seals in which the flywheel mounting is different than the earlier ones. Also the rear of the cranks on the 451's are bored for the PTO hubs.
Hope this helps
John
Bill
12-18-2001 19:39:56
 Re: Re: 425 engines in reply to JK, 12-17-2001 21:08:43
Thanks for the info. What can I do to get more hp out the 425. How much could I get and keep it together. I would like to show some of the guys with the JD 830 what a yellow one can do.
Andy
12-22-2001 12:50:08
 Re: Re: Re: 425 engines in reply to Bill, 12-18-2001 19:39:56
The roosa master injector pump is suposed to wake the GBD's up. They are $$$$
