MM steering wheel removal
Dave Ritenburgh
12-18-2001 16:39:56
Has anyone sucessfully removed, or know of a puller to remove the steering wheels on the later MM tractors? I need to remove the wheel from My 4-star to restore it, but any conventional puller will damage the hard rubber center portion of the wheel. I would appreciate hearing of any success stories.
rustytractor
12-23-2001 15:04:38
 Re: MM steering wheel removal in reply to Dave Ritenburgh, 12-18-2001 16:39:56
Have you tried a BFH?
rustytractor
12-23-2001 15:04:24
Daid Ritenburgh
01-02-2002 05:54:03
 Re: Re: MM steering wheel removal in reply to rustytractor, 12-23-2001 15:04:24
No, that is a tool only to be used on a CASE.
Unimog
12-18-2001 17:49:02
I've always had good results by backing off the
nut so it is flush with the shaft top, then with a
helper pull up on the wheel and tap the center nut
with a hammer. Give it a shot of WD40 or whatever
over night first and use light taps being careful
of the threads. So far this always worked for me.
