M5 336 tuneup
George
12-20-2001 08:08:58
I'm changeing the plugs, condensor, and points on my MM5 but don't know the gap setting for points and plugs nor the proper timing. can someone give me a hand?
Also, in setting the points I'm having trouble getting the disributor cam to stop in the right spot --- is there a special trick to this?
Thanks
Jeremy
12-21-2001 17:22:41
 Re: M5 336 tuneup in reply to George, 12-20-2001 08:08:58
George
I have a Tune up Specifications! page. at Link
You will find the point and plug gap there.
Good luck
Jeremy
JK
12-21-2001 11:43:15
George,
The plug gap will depend on if your M5 is a gas or an LP. I think .015 is correct for LP but it should be around .028-.030 for gas plugs.
John
Keith
12-21-2001 06:23:24
George,
My G705 points gap at .018 to .024 on high cam. The plugs gap at .015. The condenser should be easy to change out. When you get the plugs out, put the new points in and turn the fan to get the points on high cam. Gap them, set them, and then put in your new plugs. Good luck.
Keith
George
12-21-2001 08:14:07
 Re: Re: M5 336 tuneup in reply to Keith, 12-21-2001 06:23:24
Good tip about pulling plugs and then turning fan -- thank you
