5-Star Pressure Plate release fingers height?
Pat
12-25-2001 16:33:52
What is the correct dimension for the Pressure Plate fingers height & what is it measured from? I have ordered an IT manual but still waiting for arrival. Got to split tractor again and change pressure plate, someone thought they needed a heavy duty clutch and I can't stand it, hard to release and shift. Just split and put in new seal in TA cover and put in a new rag clutch disk, but I am going to split again and change pressure plate, I have two correct ones but I thought this one looked fine, so I did not change. If my recollection is right, previous owner had a dozer on it & I bet he changed the setup. Also which is heavier spring pink OR yellow?
Jeff
12-25-2001 17:27:23
 Re: 5-Star Pressure Plate release fingers height? in reply to Pat, 12-25-2001 16:33:52
/Remember these tractors shift easier with the Ampli-Torque on the low side.Sometimes you can`t get them out of gear when in the high side. I use 85-90 gear oil in my 5 star. Change it every year, if you do this the AT will last almost forever. Is yours gas or Lp or Diesel? Mine is a 1959 Diesel Where are you located? I`am in northestern Maryland.
