Heads for GBD
A.G.H
12-27-2001 09:22:18
While restoring this GBD I have discovered that 2 of the three heads are cracked pretty bad, (part no. 10A4214). I will be installing jugs from a G 1000 (Part no. 10A10248) and have been advised to install heads with a higher compression for power and ease of starting. Does any one know which heads would be the best? Any advice is appreciated and Thanks in advance, Happy New Year and best of luck in the future.
glenn
12-27-2001 19:27:40
 Re: Heads for GBD in reply to A.G.H, 12-27-2001 09:22:18
I have one 4214 head that has been maged,it has no cracks. 250+ shipping
Jeremy
12-27-2001 15:56:02
The 10A4214 heads have the least chamber volume of the Diesel heads that I know of so they should give you the highest compression.
I have a compression chart with many of the MM heads it is at the link below
Jeremy Fiorelli
