G1000 injector pump
mcj
12-30-2001 17:39:48
Does anyone know of a setting on the fuel injector pump that reduces the amount of smoke coming from the exhaust? It seems to be getting too much fuel.
wayne
12-30-2001 19:53:38
 Re: g1000 injector pump in reply to mcj, 12-30-2001 17:39:48
If know body been missing with the pump. Check the air filter. May be bad dirty.If that ok the flex ring in the pump broke.If you watch what your doing.You can replace it using a pump kit for a 5.7 Gm diesel.Good luck
Bobby
12-30-2001 17:56:10
if its set right they should smoke a lot. sounds like it ok.
