MM Z
mm602
01-07-2002 15:37:57
I am restoring a ZTU and need the side panel spring loaded latches.Does anyone have a source for these.I have found some but they are all too big.My local dealer says they are unavailable from AGCO.Any help would be appreciated.Thanks
ryan
01-09-2002 21:19:29
 Re: MM Z in reply to mm602, 01-07-2002 15:37:57
Whoa! I have got to save you! You can buy these latches, the closest thing besides getting an original is at NAPA. There are about the same as a jeep hood latch. Try and take in what you might have and show them, they may be able to pinpoint it quickly. I am not close to my box or I could give you the number. Sill a bit pricey, around 10.00 a latch I believe. You have to rivet them back in where the old latch was, but they look nice and work very well.
ryan
Lindsey
01-10-2002 20:12:38
 Re: Re: MM Z in reply to ryan, 01-09-2002 21:19:29
Has anyone found a good way to re-attach these latches. I have scrounged junk yards and have many broken ones that I have made good ones out of for my use, but have never found a good way to reattach them, other than use cotter keys. It seems one would need a small diameter solid metal round stock that is mallable so you could mushroom the ends, like the originals. Any ideas??
ryan
01-11-2002 07:17:04
 Re: Re: Re: MM Z in reply to Lindsey, 01-10-2002 20:12:38
I beleive the best way would to use brake rivets. You nee sort of a short fat one. Rivets are getting pretty hard to find. Dad and I attatched a new hood latch to that U on photo ads and we used rivets. It wasn't the prettiest job in the world but it is solid.
ryan
Kelvin
01-11-2002 18:34:04
 Re: Re: Re: Re: MM Z in reply to ryan, 01-11-2002 07:17:04
I have repaired those latches that only had broken springs by twisting out the old spring and twisting in a good new spring of about the correct size, using needle nose pliers. Then to put them back in the mount, I use 8-penny nails. I cut them 3/8" or so long, hold the end of the nail against the grinder and when they get red hot the end mushrooms out and doesn't come out of the hole.
Jim Parisot
01-07-2002 18:18:39
mm602,
As of a few months ago these were still available. You might want to try another dealer, or try a couple of the parts suppliers listed here. Or else, just start hitting the junk yards, or advertise for them. Hope this helps.
Jim
Kelvin
01-07-2002 16:23:29
Check with Les Wenzel he's on the MM website jetstar.minneapolis-moline.com go to the parts suppliers section for his phone no.
