Did minny mo come with a fairbank fm-j4b73 mag
elwood d. large
01-09-2002 13:45:28
i was told that some molines came with the fair banks fm-j4b73 mag. is this true and where would you find one? thank you very much for your time
J. Jones
01-10-2002 18:32:13
 Re: did minny mo come with a fairbank fm-j4b73 mag in reply to elwood d. largey, 01-09-2002 13:45:28
I have a '47 R with a FM-K4B Mag. found it in a tractor salvage yard on a '41 RT that had a cracked crankcase. By my information a Z uses a FM-RV4 or a K4B, an U uses a FM-O4B, and a GT uses a FM-O4B also. I do cannot find a listing for the mag. that you are asking about. It must be on another brand of tractor. Fair warning the points for a K4B mag. are hard to find and are expensive! I found a man that is retired that use to do generator and mag. work. He called a supplier out of Chicago to get them. They cost me $30 and the condensor was seperate. (He wouldn't let me know who they where, probably affraid I would cancel my order and order them myself.) They only had one set at the time. Big-A, NAPA, and Road Pro did not carry them, but they did carry the condensor. Get a I&T shop manual for MM. It tells you how to install your mag. And also list the other mags for the other tractors it covers. You have to remove your oil pump on a R or Z. Havn't checked out a U or G. Good luck J. Jones
