Hydraulics on MM 4 star
avery
01-10-2002 15:16:05
Recently bought a MM 4 star. Hydraulics and power steering do not seem to work. It has an outside pump on rear. What would be a series of things to check to find out the problem
JK
01-10-2002 18:05:39
 Re: Hydraulics on MM 4 star in reply to avery, 01-10-2002 15:16:05
Check the fluid to be certain that it is within about 3/4" to 1" of the surface of the housing where the plate with the two horizontal levers under the seat bolt on with 4 bolts. If the level is correct, and the 3 point doesn't move at all the pump could be shot or the coupling that drives the pump could be broken or missing. There could be other problems that would affect either the steering or the 3 point, but not both, unless there is more than one problem.
