Help for stuck engines
Steve Eagle
02-11-2002 10:28:41
I have a solution for a common problem found on minne motors with jugs that have pistons stuck tight. I took a spark plug and welded a grease zert in it and used a grease gun to pump the pistons out.Works like a dream as long as the valves seat and there isn't a crack in the cylinder wall. Hope this helps
JK
02-11-2002 14:30:04
 Re: Help for stuck engines in reply to Steve Eagle, 02-11-2002 10:28:41
Word of caution!
If the block has been bored much you risk the possibility of cracking the cylinder if you use too much pressure! Speaking from experience.
John
Steve Eagle
02-12-2002 17:56:23
 Re: Re: Help for stuck engines in reply to JK, 02-11-2002 14:30:04
Thanks for the word of caution. This is more or less a last resort for very tough cases
Steve
