Low Compression
Trever Maas
02-11-2002 18:18:15
My tractor doesn't have enough compression to fire when I crank the engine over. It has sat for over a year without cranking. Could the valves not be seating? It must be getting oil if I crank it over.
Trever Maas
02-15-2002 08:24:11
 Re: Low Compression in reply to Trever Maas, 02-11-2002 18:18:15
I found out why it wasn't starting. One of the exhaust valves was sticking and I wasn't getting any gas in the goveno
galen
02-11-2002 21:15:10
A lot of times after setting a while rings dry out. Squirt a couple shots of light weight oil in cylinders. Used to have combine had to do this to after setting between harvests, Started fine after I ran it for a while.
Trever Maas
02-12-2002 12:19:30
 Re: Re: Low Compression in reply to galen, 02-11-2002 21:15:10
Thanks. I'll try it.
