Light Switch for ZTU
Trever Maas-MN
02-17-2002 08:35:08
Where can I find a 3 position light switch for a ZTU?
Jeff
02-17-2002 17:37:59
 Re: Light Switch for ZTU in reply to Trever Maas-MN, 02-17-2002 08:35:08
A switch from a John Deere 620 720 ect... will work and you can get these new from a Deere dealer
Trever Maas-MN
02-18-2002 08:03:12
 Re: Re: Light Switch for ZTU in reply to Jeff, 02-17-2002 17:37:59
Thanks. Are they three-way switches?
Jim Parisot
02-18-2002 16:45:59
 Re: Re: Re: Light Switch for ZTU in reply to Trever Maas-MN, 02-18-2002 08:03:12
Trever, I don't think the J.D. switch is what you want, it is a great replacement for a ZA/ZB or later R, U, G. It is a 5-position switch with a little handle that you twist. You are talking about a push-pull switch aren't you? Try some of the usual M-M parts suppliers, seems that someone had one of these at the PGR convention this weekend. Hope this helps.
Jim
Trever-MN
02-18-2002 19:05:46
 Re: Re: Re: Re: Light Switch for ZTU in reply to Jim Parisot, 02-18-2002 16:45:59
Yeah, i'm looking for a 3-position push/pull switch. I've looked pretty much everywhere and can't find one. Maybe there are some universal switches but none like that with the high charge, dim, and bright. Possibly some salvage places have some around but probably aren't very good. The one that I have works but isn't too consistent. Seems like dim works better than bright if bright works.
Jim Parisot
02-19-2002 06:39:28
 Re: Re: Re: Re: Re: Light Switch for ZTU in reply to Trever-MN, 02-18-2002 19:05:46
Trever,
You might want to try Jim at Agri-Services - www.wiringharnesses.com - he sells a 3 position switch for tractors with the cutout relay for $49 + $4 S&H. Don't rule out the salvage yards, you just never know what you'll run across.
Jim
Trever Maas-MN
02-23-2002 15:48:42
 Re: Re: Re: Re: Re: Re: Light Switch for ZTU in reply to Jim Parisot, 02-19-2002 06:39:28
Was it Les Wenzel that had the light switches at the convention? He usually has a table full of misc stuff sitting out at the conventions.
Jim Parisot
02-25-2002 12:23:43
 Re: Re: Re: Re: Re: Re: Re: Light Switch for ZTU in reply to Trever Maas-MN, 02-23-2002 15:48:42
You've got it! ! !
Trever Maas-MN
02-26-2002 19:24:15
 Re: Re: Re: Re: Re: Re: Re: Re: Light Switch for ZTU in reply to Jim Parisot, 02-25-2002 12:23:43
I gave him a call and left a message on Saturday. He hasn't called back yet. He must be gone somewhere.
Trever
