M-M M-5 alterator conversion
Phillip
02-18-2002 09:21:11
I was wondering if anybody else has but a alterator on a M-5 diesel? I have the factor wires but some of them are cut off A picture of the wiring would be helpfully if some one has one to share Thank You in advance Phil
Darrell
02-18-2002 21:22:03
 Re: M-M M-5 alterator conversion in reply to Phillip, 02-18-2002 09:21:11
You can use a Delco self energizing alt. The only wire you need is the large hot wire.Tisco has this alt, or a good alt. repair shop.
Mike (WA)
02-21-2002 08:29:30
 Re: Re: M-M M-5 alterator conversion in reply to Darrell, 02-18-2002 21:22:03
And that one hot wire goes to the same place as the wire from the BAT terminal of the old voltage regulator went.
Darrell
02-18-2002 21:21:48
