MM 4210 Heads
Jason
02-24-2002 07:03:10
Where can you get 4210 heads or who welds them? Do they have good luck with welded ones. I'm in the North Central Iowa area.
LMS
04-10-2002 21:14:48
 Re: MM 4210 Heads in reply to Jason, 02-24-2002 07:03:10
I CAN GET YOU ALL OF THE 4210 HEADS YOU NEED .
THEY ARE NOT WELDED,JUST GOOD HEADS. I ALSO HAVE ENGINE PARTS TO REBUILD THESE ENGINES THANKS JUSTIN
deadeye
02-24-2002 07:47:45
Try Williams Cylinder Head Co. out of Nevada, Ia.
1-800-873-8506 talk to Rex Barker if he is still there. I have had a couple of heads welded there.
That's all they do is weld heads and blocks. Been in business many years. Nevada is right straight east of Ames. They put them in an oven and get them red-hot before they start welding. Quite an expearence to see it done. All smooth edges are surface ground when complete. Looks like new. deadeye
