MM Gs
JKC
02-27-2002 18:59:47
What model (GB, GBD, etc.) was the MM G that was powered by LP? Did they make a lot of these? What are they worth today if engine is stuck vs if running?
Thanks.
Unimog
02-28-2002 06:55:40
 Re: MM Gs in reply to JKC, 02-27-2002 18:59:47
The GBD is a 6 cyl. diesel only. The GTB, 1947-54
and the GB, 1955-59 used the 403 4cyl in LPG or
gasoline. The GTC, 1951-53 used a 340 4cyl. that
only used LPG. The GTC is the rarest version with
only 1107 made. All were good heavy big power for
their time. Values seems to be all over a wide
range. Lows in the $600-700 to highs in the range
of $4000-5000. Gas or LPG doesn't seem to effect
price much. A stuck engine would certainly put
the price down. They are most commonly found in the wheatland areas of Canada and US. Because of
supply in these areas, the prices are usually low.
Curtis Rink
02-28-2002 09:41:10
 Re: Re: MM Gs in reply to Unimog, 02-28-2002 06:55:40
In the plains states, you'll find many G's and GTB's (1947 to 1954) with the 403 that were converted to LP. My understanding is these conversions were done by the dealer or the farmer.
