Distributor shaft bushings
DLP
02-28-2002 10:24:21
I need to rebuild the distributor on my MMU. What size bushings will it take? I'd like to get them before I take it apart. Also, will a seat bracket off a '44 uts fit a '46 utu? I know it will bolt up, but are they bent the same?
Jim Parisot
03-07-2002 09:36:47
 Re: Distributor shaft bushings in reply to DLP, 02-28-2002 10:24:21
DLP,
I think you'll have to just take your distributor apart and then press out the bushings and take them to a good bearing supply house and match them up, if you haven't done so already. As far as the seat bracket, the parts book shows them to be the same.
Jim
