Location of serial number
DMW
03-02-2002 04:21:13
Where are serial numbers located on averys which were sold as M/Ms, like BF etc ? Thanks
Pete-mi
03-02-2002 10:12:19
 Re: Location of serial number in reply to DMW , 03-02-2002 04:21:13
They were usualy stamped on the top of the right frame rail by the brake pedals. On some late model units they had a tag rivited on the frame by the clutch bell housing.
DMW
03-03-2002 17:30:23
 Re: Re: Location of serial number in reply to Pete-mi, 03-02-2002 10:12:19
These are both single front wheel models and the numbers don't make since to me for the info I have, they are 11a-786, 11a-006, can you make any since of this they both prarie gold under everything.
Pete-mi
03-03-2002 21:02:10
 Re: Re: Re: Location of serial number in reply to DMW, 03-03-2002 17:30:23
From what is shows on my serial number list they would both be made in 1947. That was before M-M purchased the Avery Company. The serial number matches with the model "A" made by the B.F.Avery Company.These serial numbers would be stamped in and not raised numbers. The model A had a bar type grill and the later M-M BF has a wavey mesh grill like a JD R,80 ect. If it is a model A it may be a primer that they used that had the yellow color or it may have been painted by a dealer or customer to make it look like the newer model. Keep me updated here as to what you find.
