Compression ratio
Brian Williams
03-02-2002 17:49:31
Can anyone tell me the copression ratio of a 1947 MM UTU with the KEF engine and the HC gasoline head. I believe is number is 282C, but don't quote me on this. The head has a big H-C on the spark plug side.
Thanks in advance,
Brian
Brian Williams
03-03-2002 19:33:14
 Re: Compression ratio in reply to Brian Williams, 03-02-2002 17:49:31
Thank you for the replys I visit Jeremy's site quite often. I am curius also like the last person to post is...I am assuming H-C means high compression, Because, I have heard of L-C heads. The H suffix head would be for propane?
Taylor Marret
03-03-2002 13:03:15
Jeremy Fiorelli has an almost complete list of compression ratios and the like on his site, twin city and minneapolis moline tractor and pulling page.
Jeremy
03-03-2002 19:23:03
 Re: Re: Compression ratio in reply to Taylor Marret, 03-03-2002 13:03:15
Thanks Taylor for telling him about my site! I don't have the solid block head info there. I have the information just haven't put it up there yet.
Here is the few compression ratios I have for the solid block heads. You have to remove the valve cover to find the number it is between the secound and third cylinders.
KE282C is 4.3 to 1 compression
KE282D is 5.4 to 1 compression
KE282H is 6.8 to 1 compression
les
03-03-2002 18:42:26
what does H-C stand for???
Kelvin
03-06-2002 13:12:37
 Re: Re: Re: Compression ratio in reply to les, 03-03-2002 18:42:26
I think it stands for High Compression
