MM 445 Exhaust Manifold
Ed Haas
03-08-2002 17:08:39
The exhaust manifold on my 445 has a cover plate at the front of the manifold held on by two bolts. A friend told me this was to allow for an exaust system to be run out of the back of the tractor. The gasket for this cover plate blew out and I decided to fix it rather tan put up with the noise. When I removed it, the plate cracked in two. What is the correct name for this part and are they available from Agco or will I need to find an MM bone yard or have one made?
Kelvin
03-08-2002 18:08:15
 Re: MM 445 Exhaust Manifold in reply to Ed Haas, 03-08-2002 17:08:39
I had the same problem, except I dropped mine when I took it off. I cut one out of 1/4" plate and made a gasket out of head gasket material. I bet one of the MM parts suppliers can help you, at least with the gasket. go to jetstar.minneapolis-moline.com and look under parts suppliers.
I like to deal with Welter's and Everett's.
Paul Beard
03-22-2002 07:47:11
 Re: Re: MM 445 Exhaust Manifold in reply to Kelvin, 03-08-2002 18:08:15
You can still get these from your dealer. No gaskit was used on this plate. One fabracated from a flat plate works fine, mine did. There is also no gaskit shown in the parts manual for a gaskit on the center pipe adapter.
Ed Haas
03-08-2002 19:06:22
Thanks, Everett's is not more than an hour from here. If the Agco dealer doesn't have one, I'll call him.
The original plate was flat on the out side but had a concave area on the inside. I am assuming that this aided flow due to smoothing out the stream instead of bouncing off a flat plate? I take it you didn't notice any difference with the flat plate that you made out of 1/4 inch?
Kelvin
03-09-2002 17:28:19
 Re: Re: Re: MM 445 Exhaust Manifold in reply to Ed Haas, 03-08-2002 19:06:22
I couldn't tell any difference in the flat plate.
The only difference is that it is steel and not cast iron.
Kelvin
03-09-2002 17:27:57
Lindsey
03-09-2002 06:29:46
Wouldn't you be able to take like a 4" angle grinder and sort of grind out the concave like the old one? I think that if you were careful you could do a pretty good job of re-creating a near stock part.
