445 crank
bill schaller
03-08-2002 18:25:25
I have been offered a 445 with gas engine. the only problem is there is a clacking noise from the crank shaft. the owner says a collar has broke off the end of the crank, at the end bearing, and it is a fairly easy fix. should i make a cheap offer, or run away.
Bill
03-09-2002 20:27:09
 Re: 445 crank in reply to bill schaller, 03-08-2002 18:25:25
Take off the side cover and have a look They usually spin the center main and then break the crankshaft. I would be careful
