M-M U heads?
Jeff Oliver
03-12-2002 16:11:04
I am wondering what compression heads I have on my U. I number cast on the sdie is GE-30-E. Is this the number I need? If so are these low comp..or high? I am debating on pulling with it but am not sure I want to do a whole lot to it as it runs really good.
Jeff Oliver
03-12-2002 20:08:22
 Re: M-M U heads? in reply to Jeff Oliver, 03-12-2002 16:11:04
Ok I checked the site and the chart. Of course now I am still confused as that number is listed twice and with 2 different compression ratios. One is witha smaller engine and tractor fuel which I don't think mine is set to run as there is only one fuel tank on it. That one is 5.4-1. The other is a larger engine I think and reg gas which shows it at 7.08-1.
humm ya know, that compression tester is looking better and better.:)LOL!!!
Family Tradition
03-12-2002 17:26:38
10A4213 and a GE30J are both LP heads! The best place to compare heads is on Jeremy Fiorelli's site.... Lots of info on his site!
Kelvin
03-12-2002 17:16:48
What you guys need to do is check out the chart on Jeremy Fiorelli's MM tractorpulling website.
Http://members.tripod.com/Fiorelli/index-5.html
If that doesn't get you there, do a search for Minneapolis Moline. I think it will show up there.
My '49 UTS has GE 30 E heads on it, too. I think these were the standard low altitude gasoline heads. I'm sure there was a LP head, and probably a high altitude gasoline head as well.
scott
03-12-2002 16:25:41
I saw your question about heads as I was just getting ready to ask basically the same question. Surely someone can post one of the charts that compares the different compressions. I need to know about GE30J,10A4206, and GE30F.
Dave N
03-13-2002 05:13:14
 Re: Re: M-M U heads? in reply to scott, 03-12-2002 16:25:41
10A4206 8.35 to 1 in a U 10.85 to 1 in a G 30J 7.55 in a U 9.9 in a G 30F 5.5 in a U 7.3 in a G
