H-C head= what?
scott
04-03-2002 17:45:43
I have seen two different MM engines with H-C heads on them. Does anyone know what number they are equal to?
Jeremy
04-03-2002 19:54:31
 Re: H-C head= what? in reply to scott, 04-03-2002 17:45:43
There are a few differen't H-C heads with the solid blocks. You have to remove the valve cover to see what head you have on the solid blocks. Below are the solid block head numbers and compression ratios. I think and I'm not sure on this but I think the GE30 head numbers are under the valve cover on the split block heads at least the later one's. I'm really stabing in the dark on that one I'll have to look at some of those heads again to know for sure.
KE282C is 4.3 to 1 compression
KE282D is 5.4 to 1 compression
KE282H is 6.8 to 1 compression
Jeremy
scott
04-04-2002 18:22:48
 Re: Re: H-C head= what? in reply to Jeremy, 04-03-2002 19:54:31
Thanks guys, I'll do some further research.
Kelvin
04-04-2002 17:26:16
The GE30 head #s are on the side of the ones I have had to personally check. example: GE30E
Darrell
04-03-2002 18:26:34
H-C means high compression.
