MM BF Paint Color ?
Rick
04-06-2002 03:37:47
My father is in the process of restoring a 1953 MM model BF and would like to know if it should be prairie gold. It has been painted a couple of times and its hard to tell what the original color was. If you could supply me with the paint codes Iwould appreciate it. We generally use PPG paint. Thanks in advance Rick (ME)
Pete-mi
04-07-2002 20:48:08
 Re: MM BF Paint Color ? in reply to Rick, 04-06-2002 03:37:47
Your tractor should be Prarie Gold with red wheels. The outer rear rim is usualy painted silver. The rear center dish and front rims are red. Before M-M purchased the Avery company all small Avery tractors were painted red. Shortly after the M-M purchase they painted them the M-M colors and added the M-M hyd system. Agco offers the prarie gold paint in quarts and the munber used is #79014808. I personaly like using this paint as they also make spray cans of it so you can touch it up if needed later and the color matches.
Jim Parisot
04-06-2002 07:54:04
Rick,
Ditto on the Prarie Gold number, the red you want is DAR72083 H, it's a perfect match. DON'T use IH red.
Jim
Steve G.
04-06-2002 09:07:44
 Re: Re: MM BF Paint Color ? in reply to Jim Parisot, 04-06-2002 07:54:04
Why would anyone use IH red on a moline tractor? thats just stupid if you ask me. thats my .02 worth
Rick
04-06-2002 08:01:59
Thank You both for your quick response.Rick (ME)
Unimog
04-06-2002 05:08:16
Rick, your tractor should be Prairie Gold #2 with
cherry red wheels. The PPG code is DAR-60039 in
acrylic enamel for the gold.
