Minn Moline UTI!
Dave
04-07-2002 07:31:43
I have a Minn Moline UTI, it is a front loader but I dont have any info on the tractor. If anyone could give me links or knows anything about these please e-mail me. Thanks Dave!
Ken Savener
04-20-2002 19:57:44
 Re: Minn Moline UTI! in reply to Dave, 04-07-2002 07:31:43
I have a I&T shop service manual for a M-M UTI-tractor model L if it would you any good
Sonny Heath
04-14-2002 21:28:45
Dave, Are you the Dave from near Deloraine Manitoba? If so, would you email me your phone number please? I need to talk to you and have lost your email address. sonny@aic-fl.com
Roger
04-07-2002 18:18:00
Dave, I have a 1946 UTI, it never had a loader on it. Grandpa bought it when it was 5-6 years old. What info did you want, I'll try to help..... Roger
Jon Hineman
04-08-2002 12:19:41
 Re: Re: Minn Moline UTI! in reply to Roger, 04-07-2002 18:18:00
Are you familiar with the braking system on the MM UTI? It is quite a bit different from my other MM U's. We just got the thing in the shop and it looks as though it might be difficult to work on. Everything is built very heavy, and the brakes appear to be located in the wheels themselves. It has a huge nut-- probably about 4 inches across on the end of the axle. The wheels themselves appear to be "split" that is... of the split-rim variety. This may be a very interesting restoration. Thanks, Jon Hineman
Roger
04-08-2002 23:42:14
 Re: Re: Re: Minn Moline UTI! in reply to Jon Hineman, 04-08-2002 12:19:41
Jon, Does your cast wheels have a part # of FT2295B close to that big hex nut? if so you have the same wheels as mine. You are right about them being HEAVY, I can't personally say that with experience, but Dad told me they are, he & Grandpa had them off back in the 50's. They are Bendix brakes & yes they are inside the cast wheel rather than up on the differential shaft like the row crop U's. Mine didn't work too good until a few years ago when Dad got under there & set them up. They work good now. If my scanner worked I could scan the manual I have to show you the page on the brakes. I have no idea if lining is available anywhere unless you could find some o the same diameter & drill them to fit..... .Roger
lance
04-08-2002 11:48:47
try www.minneapolis-moline.com
