MM BF Timing
Tom Mooney
04-16-2002 07:10:28
Discovered that my BF that was hard to start was out of time. We lined up the cam and crank using the two dots on each but this throws things about 180 degrees out of time. There is also a letter "s" on each gear. What should I line up? Any help is appreciated.
James Sheets
04-22-2002 13:19:45
 Re: MM BF Timing in reply to Tom Mooney, 04-16-2002 07:10:28
You can fix the problem by selling your Minny Mo and getting another John Deere. Just kidding, see you at the tractor show.
James
Kelvin
04-16-2002 13:19:02
Don't know where the problem is. My manual says to align the punch mark on the crankshaft gear with the punch mark on the camshaft gear.
The picture shows the engine with just the timing cover removed, oil pan still on. so you're looking at the front of the engine.
