8 volts instead of six volts?
John Kauzlaric
04-18-2002 18:27:31
Would using an eight volt battery instead of a six volt one hurt anything on a U ?
Brian F. Williams
04-18-2002 18:30:21
 Re: 8 volts instead of six volts? in reply to John Kauzlaric, 04-18-2002 18:27:31
I use an 8 volt on a U. Works fine for me. Worked well with resistor light switch and now a voltage regulator. Just had to calibrate the regulator for the increased voltage.
Pete Brandel
04-18-2002 20:45:17
 Re: Re: 8 volts instead of six volts? in reply to Brian F. Williams, 04-18-2002 18:30:21
I have a R Moline that we have had an 8 volt battery in for about 5 years.It starts much better and seems to work just fine .
Tom in Mo.
04-20-2002 17:11:56
 Re: Re: Re: 8 volts instead of six volts? in reply to Pete Brandel, 04-18-2002 20:45:17
Does the generator keep an eight volt fully charged?
Tom in Pa.
04-21-2002 19:35:50
 Re: Re: Re: Re: 8 volts instead of six volts? in reply to Tom in Mo., 04-20-2002 17:11:56
I use 8 volt batteries,no problems.**
A 6 volt system will charge at 8 volts anyways. (Just like a 12V is charged at 14V.)
** I CAREFULLY make my own 8 volt batteries by
cutting two dead or damaged cells off the end of
a junk or damaged 12 volt battery.
Phil Munson
04-22-2002 11:08:26
 Re: Re: Re: Re: Re: 8 volts instead of six volts? in reply to Tom in Pa., 04-21-2002 19:35:50
Used 8V for twenty years in 2 cyls with high comp pistons. When you turn on the lights it helps to idle down the tractor before you throw on the switch so you do not blow the lights. Never experienced any point problems.
