Distibutor insulator
Harold
04-25-2002 08:39:25
Where can you get the little insulator that goes thru the distributor and the coil wire fastens on the outside and on the inside the points and condenser fasten. It has a little bolt thru it with a nut on both ends. It appears to be made of plastic or hard rubber. The factory no longer makes them. It goes on a M5 LPG. Thanks for any help. Harold
moline-1
04-26-2002 19:35:05
 Re: Distibutor insulator in reply to Harold, 04-25-2002 08:39:25
Harold, I hate to admit this but I bought the one for my 602 at John Deere.I also have an A and rebuilt the distributor on it and JD had everything.So when I needed one for my M602,thats where I got it.Good Luck! Moline-1
deadeye
04-25-2002 10:20:46
Harold: What you are looking for is the insulators that go in the square hole of a Delco distibutor isn't it?? Try a junk yard that has old Chevies or GM products. I once made one out of some long threaded screws and a piece of thick teflon. Used the screw like a piece of red-i rod after I cut the head off. Another place that might have something may be a Mag. shop. It's about as hard to find them anymore as it is to find the post you are looking for.---deadeye
Harold
04-26-2002 20:01:45
 Re: Re: Distibutor insulator in reply to deadeye, 04-25-2002 10:20:46
Thanks deadeye and Moline-1. I'll try John Deere first and then a salvage yard if I need to. Thanks again. Harold
