4 star torque
Doug Dewing
04-29-2002 20:11:46
The torque on this tractor only works in low range. Pushing forward into high range does nothing. Tractor continues in low range. Anyone got any thoughts on what could be wrong and potential costs to fix? I overhauled the torque on a jetstar 3 many years ago, but can't remember how it works. have another jetstar 3 that I may part out.Would amplitorque parts from that work on the 4 star? TIA
JK
04-30-2002 06:58:47
 Re: 4 star torque in reply to Doug Dewing, 04-29-2002 20:11:46
Doug,
if it works in low but not in high, for some reason the clutches are not engaging when pushing the lever forward. If the handle makes a distinct snap when pushing forward and requires some effort to push, the 'ears' are probably broken off the outside of the brass clutch disks, if it pushes forward real easy with no snap, it may just need adjusted through the hole under the lever. Some of the parts from the Jet 3 will interchange.
John
